TrueTone D-717 filter cap polarity
The schematic is not marked and someone has been in here before and I want to put things back so.
C11 neg goes to chassis pos to 80 heater
C10 Neg to center tap Pos to 80 heater?? or am I backwards?
http://www.nostalgiaair.org/PagesByModel...023887.pdf
Both correct.
Interesting how the field coil is run on the negative side of the power supply, I haven't seen that before.
Just wired it in they had one wrong, when I first brought the up voltage and when the set was at full voltage it had a loud 60cyc hum but that's all gone now. Thanks
Eric
Sure. Did you replace the one that was wired wrong? Hundreds of volts the wrong way across a cap will likely shorten its life if it isn't already dead.
Well I have found 315v on the rectifier when cold. Drops off to 280 after 15 minute warmup. Checked pin 3 on both 6F6 t...murf — 04:14 PM
Thanks for the replies, I will check these ideas out and report back. murfmurf — 03:18 PM
Sorry, my mistake. murfmurf — 03:07 PM
MrFixr Honestly, I haven't done that yet and do not want to screw up the threads; maybe you could do it, or we could...morzh — 12:48 PM
Two small radios from France. Restoration and review.
Greetings; I think that it's possible that the assortment of components was the result of post war parts shortages, a...Arran — 12:18 PM
Unfortunately I can't inject any audio into the volume control. It is in the primary circuit of the antenna coil, not in...Stormlord5500 — 09:32 AM
Sounds good Gary I'll do that. I have plenty of stuff like that I can scrounge up. I am still kind of new to all this so...Stormlord5500 — 08:47 AM
Philco Battery-WWII vintage
Seems to me that this a general purpose or radio filament 6V battery of very high amp-hour capacity and very high "...MrFixr55 — 08:08 AM
Hi Morzh, From my end, no. I did not know that there are 2 threads on this topic. Maybe it should be combined.MrFixr55 — 07:13 AM
Any reason for the 2nd copy of the thread?morzh — 10:22 PM
