Hammond 124E transformer - error in datasheet
http://www.hammondmfg.com/pdf/124E.pdf
The numbers did not make sense (impedances vs turns ratio) so I called them. Spoke to a guy in tech and he said that the datasheet is in error and the turns ratios are:
1:1.2.968 (serialized outputs; the datasheet calls for 5.94)
1:1.484 (paralleled outputs; the datasheet calls for 2.97).
This makes impedances work out.
Another error is it lists 7000 Ohm at the CT on the transformer symbol.
According to the rep this is not correct, he did not give me correct number but I think correct should be 15K/1.414 = 10,600 Ohms.
Just in case you use it and want to know the conversion.
Thanks for the heads up! Icon_smile I had to go double check I hadn't ordered one of these.. but I bought the 125H instead.
125H is an output transformer, I am talking of an interstage type. Big difference.
I realized that after I wrote what I wrote.. I should've deleted it. The 624 I restored had an open primary on the interstage transformer. it was the 124D we figured out would probably be the best match. so I knew the 124 series factored into my memory somehow.. ;-)
124D would work but the ratio of 1:1.5 will cut the volume noticeably, considering the needed ratio of 1:4.
Philco model #20
Hello again fellows , well I powered up the set this evening after I had changed every cap and resistor in this set and ...onlyrick — 09:34 PM
Yes - better it happened on the repair bench than returning to the owner. The other question is - do I also dissect a...EdHolland — 09:08 PM
That's a bummer but get them now. Paul BPaul Philco322 — 08:27 PM
I completed the insulation on the cabinet interior (Al foil and hi temp silicone rubber), and reglued the speaker gasket...EdHolland — 06:18 PM
Tim - Photos of 8 octal tube sockets. (Top and bottom) Send me a PM if you're interested.RodB — 04:11 PM
VTVM meter moves when my hand is next to it & not on
Haha! I hope so. It seemed rather lost and forgotten languishing in the frozen Northeast of England.EdHolland — 02:36 PM
Ed - it's in the Cayman's enjoying the good life.RodB — 02:14 PM
Static electricity - but the other chaps beat me to it again. I've seen this before with analogue meters. I've also ...EdHolland — 01:56 PM
There are currently 1202 online users. [Complete List]
» 5 Member(s) | 1197 Guest(s)
AvatarAvatarAvatarAvatar
