Please be specific in your post subjects.
Please be specific in your questions, as well as the subject title you give your questions. Specific questions will generally be answered quicker than those of a generic nature.
Good subject title: How do I test a Type 45 tube from my Philco 90?
Bad subject title: Philco Radio
Also, please do not make multiple posts asking the same questions. This is merely a waste of bandwidth. A lot of us have jobs - and lives - that prevent our being at the computer 24/7. Please be patient, someone will post when they can. It is OK to "bump" your question, if necessary, by merely typing:
bump
as a new post in your thread to help bring attention to it.
This should not be construed as picking on anyone. The questions, comments, and contributions of everyone here are all very much appreciated.
Thanks.  Icon_biggrin
Peter; I found an old thread on the ARF, I was wrong about when Rogers took over DeForest Crosley, it looks like it wa...Arran — 06:15 AM
Thank you Arran, this is very interesting information. With your permission, I will definitely use it when I make a vide...RadioSvit — 04:14 AM
Peter; For a start your DeForest Crosley 6D632 was a 1936-37 model, and I believe it had six tubes, and 3 wave bands,...Arran — 03:07 AM
AES type of Battery Eliminator has hum in B+
This is interesting, they actually designed the B+ side with some form of voltage regulation, I think? Most of the B+ su...Arran — 02:21 AM
They are trying to use a regulator. Essentially it is an LDO schematic. LDOs are supposed to greatly reduce ripple, so t...morzh — 12:11 AM
So, I just built a 90 volt 40ma battery eliminator for a farm radio and had to use 1000 mfd for the input filter cap to ...RodB — 10:31 PM
Caps of 1,000 uF 250V are about $7 in Mouser. C1 could be increased. A NTC inrush limiter could be employed to limit t...morzh — 10:24 PM
Bruce B — 09:41 PM
Bruce Could you post the schematic if this power supply?morzh — 09:31 PM
Hello All, I have built a battery eliminator using the most popular AES K101a. Using plans and all the AES parts  order...Bruce B — 09:27 PM
There are currently 1705 online users. [Complete List]
» 1 Member(s) | 1704 Guest(s)
