Shouldered Tombstone 116-121
Gentlemen,
I am new to this forum and been with my radio hobby about 2 years and enjoying it more everyday.
I just began working on a Philco 116-121.
I could use a schematic and a parts list??
Is there a code I could follow on the paper capacitors??
They just list a part number with no values, i.e. 30-4024, 30-1034???
Thanks for any help!!
Matt
mtroy1369
Are paper caps tubular? Those usually do have values and voltages on them. Some could be found here.
http://philcorepairbench.com/papercap.htm
1000 VOLTS WORKING VOLTAGE
Capacity Mfd. Part No.
.006 30-4024
Schematics and free other information here:
http://www.philcoradio.com/tech/images/116px.jpg
http://www.nostalgiaair.org/PagesByModel...013121.pdf
http://www.nostalgiaair.org/PagesByModel...013122.pdf
Have a look and see which one is your chassis.
Then, if you need, better clearer copies at a very low cost contact
http://www.philcorepairbench.com/schematics.htm
Justradios.com has capacitor kits as well instead of buying them individually
AJ
Go mountaineers!
Thanks a million gentlemen!!!!!!!!!!!!!!!!!!!!!!!!!
I appreciate the Philco code page for the fixed paper capacitors.
All they had on them was a Philco part number, this really helped with the values.
The schematic and parts list is quite helpful also.
Thanks again,
Matt
mtroy1369
Welcome to this site, Matt. The 116 tombstone is one of the best table sets out there.
Strongly advise:
1. Take a good look at the different areas on this site. MANY questions can be answered here!!
2. Re-stuff the "bakelite block" capacitors under the chassis. The blocks also serve as "tie-down points" for the wiring.
philco predicta
Philco 91 code 221
Philco 91 code 221
Philco 91 code 221
There are currently 1246 online users. [Complete List]
» 1 Member(s) | 1245 Guest(s)
