Philco 46-480 stain tones
What were the original stain colors used on the Philco 46-480? What modern approximations are available?
Hi
The original finish used tinted lacquers to achieve the desired colors instead of stain.
Medium Walnut would be a good match for the overall color of the cabinet, with a light coat of extra dark walnut for the foot. If memory serves, I believe the insets of the grille bars used photofinish, as did the center "bar" surrounding the cabinet, and the upper left and right panels. The wood bezel surrounding the dial definitely used photofinish.
If you've stripped your cabinet, then the photofinish is gone forever. You can use the Stewart Schooley method to replicate it, or just use toning lacquer to make it look decent.
Nice job on the battery, Bob. Can the box be opened to replace the 9 volters?RodB — 11:32 AM
Thank you for the detailed response MrFixr. To clarify, the hum starts when the tubes are fully warmed up, and goes a...sq65 — 09:15 AM
MrFixr The chassis, if there is no ground pin in the AC plug, due to the Y-caps from L/N to the chassis, is at 60VAC re...morzh — 08:47 AM
schematics
thanks I'll try the polar caps seperatelymseno — 07:38 AM
Hi SQ55, A strange issue indeed!  Just so I have you straight, on a dim bulb you get normal operation after the set warm...MrFixr55 — 12:44 AM
schematics
I think mseno is talking about cap# 27 which is a multisection but in a paper tube. In cases like that I've usually be ...klondike98 — 11:25 PM
schematics
Ohrenet  :roll: For their price I would chase a fly in a field.  :twisted:Vlad95 — 11:21 PM
A bit more work on the Motorola. I got the repro battery together right up until I realized the snap clips on the top o...klondike98 — 10:45 PM
schematics
Often restuffed. If a twistlock, Hayseed Hamfest makes modern replacements. morzh — 09:18 PM
schematics
Looking for a multi-sectional 8+16 mfd cap. Can't find any suppliers that carry it.mseno — 08:45 PM
There are currently 1247 online users. [Complete List]
» 2 Member(s) | 1245 Guest(s)
