Philco 38-690 restoration
#31
It is finished. It is aligned and working on all bands.
I made wood blocks to replace the ones somebody else had lost or thrown away. The radio chassis just sits on four rubber chassis supports on the slanted top shelf, so the wood blocks prevent it from sliding out.
[Image: http://i269.photobucket.com/albums/jj77/.../016-9.jpg]
The bottom of the power supply and amplifier chassis - the thin gray wires are redundant grounds, to supplement the rivets on the terminal strips
[Image: http://i269.photobucket.com/albums/jj77/...015-10.jpg]
[Image: http://i269.photobucket.com/albums/jj77/...013-10.jpg]
[Image: http://i269.photobucket.com/albums/jj77/...014-10.jpg]
Web site: http://www.masekconsulting.net
Radio Photos: http://www.photobucket.com - album id FStephenMasek
#32
WOW well you know Icon_eek
nice job  butttt
I want I want it I want Icon_crazy stop teasing me
sam
#33
FStephenMasek, Beautiful restoration you did on this unit. I have a question, I am not sure if this radio has the same RF sub-chassis as my 37-116,if so did you have problems with the band #2 oscillator coil that seems to plague many Philcos of this type? Did you rewind this coil or find a good replacement? If you did a rewind, did you keep any notes on what you did or have any tips on doing this? Thank you in advance ! And again, you have an awesome set.
Ron
Philco 37-116.    Philco 70
Philco 52-944.    AK 84
#34
Nice job!  Icon_clap Icon_clap Icon_clap
#35
Yep, want it too.
Lucky you.
Great radio.
Knowing how my 37-116 sounds I could only imagine the sound out of this one.
#36
Thanks!
No coils needed to be replaced or rewound.
#37
I was lucky myself, in 37-116, no coils were open. Or for that matter, nothing other than standard recap-recarb was required.
Of course I got no statistics, but....to me those HiFi ones were well-made.
I have recapped this large Marconi model 86.  It plays quit good.         I have stripped the cabinet and using Mohawk...Dan Walker — 12:18 AM
Table radio 51C or 52C?
I think what you may have is another Phactory Phranken Philco, if the holes in the front panel lined up it was not unusu...Arran — 10:41 PM
Ho OSanders, Sorry, I got really busy in May and haven't seen your thread in a while.  I am VERY sorry about that.  ...MrFixr55 — 10:30 PM
Philco 45L Initial Check Up
Dan; I don't think that the model 45 is especially know for coil problems, not that they can't occur for one reason o...Arran — 10:19 PM
Yes, the end with the groove is positive, the stripe with the arrows points to the negative lead. The arrows have minus ...RodB — 09:36 PM
Thank you Rod and Paul I took a break, did some yard work and Rod "Therefore, it appears cap 40 is connected backw...osanders0311 — 06:35 PM
Hello, I am in the process of checking out a Philco 45L. My question is does this model suffer from the Philco coil r...dconant — 06:11 PM
Purchased a table radio at auction, not because I had to have it, but because no one else bid on it.  $5  Unable to fi...antiqueradionut — 05:14 PM
The 2 towns you mentioned "Frustrated" and "Give Up" are places we have all been. Relax, take 5, thi...Paul Philco322 — 03:23 PM
Philco 89 Code 123 Osc Coil
Thanks for posting that information!klondike98 — 03:14 PM
