Do any of the collectors out there have for sale any of  the half round fluted trim that fits the top edges of the 1931 Bel Geddes designed cabinets?  I just got a 370 chair side that’s missing 2 sections about 8” long.  if no one has any of the original for sale, does anyone have any reproduction for sale or tips on how to make it?  it appears from photographs that I have seen that a lot of these are missing pieces of that trim, I’m pretty sure I’m not the first one too have experienced this.  Max
If you are looking to buh some pieces, you might want to palce an ad to the Markeplace/wanted ads.
One method that some have used is to get some hardwood dowel, of the appropriate diameter, and cutting a flat onto one side to duplicate missing portions of the bead. I don't know if anyone is duplicating strips of molding for these, It could be done, but I think the way they made it was by running boards through a shaper, or molding head cutter, and then cutting it into strips, likely gluing and nailing it on.
You can get half-round moulding in various diameters at any home improvement store. That way the flat edge is uniform. - Gary
Thank you! I’ll probably use the half-round molding and tone it to match the original. Thanks for the replies!
LOL!! Well Arran, if you do dive into it and come across any advice on dealing with accessing components let me know. I...klondike98 — 11:56 PM
Bob and Gary; I have the further complication on the Phillips that they decided to use some 200 volt rated paper caps...Arran — 10:05 PM
Thx Arran & Gary. Yes its super crowded in the chassis and I've debated whether to try to restuff caps or not. I t...klondike98 — 07:40 PM
That's got to be one of the tightest conglomeration of components I've ever seen! I wonder how the line workers felt bu...GarySP — 05:46 PM
Bob; I think that the Phillips was actually manufactured in Canada, though they may have imported many of the compone...Arran — 02:28 PM
I've started replacing the electrolytic caps now. As Arran mentioned, they are housed under a metal strap. Here's a ph...klondike98 — 12:22 PM
Thank for that info Arran! Very interesting. Phillips and Motorola must have made some type of marketing deal back then....klondike98 — 11:49 AM
46-1213 Schematic Question
Good idea on the fuse. These old transformers need extra protection.RodB — 10:02 AM
Hello Larry, Well, anyway I can contest about noisey grounds in my living room when I am using one outlet in my house a...radiorich — 08:03 AM
RodB & MrFixr55, Thank you both for the great replies at my questions, I appreciate the help very much.  As suggest...MissouriLarry — 07:04 AM
There are currently 1407 online users. [Complete List]
» 1 Member(s) | 1406 Guest(s)
