antenna connections for philco 38-8
This radio has three terminals marked red, black, and ground on the back. What is the proper antenna to connect to red which appears to be for the am band and black for the shortwave band? I haven't found anything in the schematics or other product related data I've located on the internet.
Hi
The RED and BLK terminals are for use with the Philco High Efficency Antenna or other doublet antenna.
A simple longwire at least 25 feet in length will be better than no antenna at all. This is connected to the RED terminal, and will serve for AM and shortwave.
There should be a metal jumper connected between the BLK and GND terminals when a simple longwire is used.
My Philco 37-116 Restore
I found I have a cracked 6J5 (AVC) tube. Since the tube shields are so tight I must have broke the tube putting the shie...dconant — 05:32 PM
Looks like I made a mistake. I painted my tube shields silver. Now the reception is poor and can't really zero in on mos...dconant — 01:10 PM
Need Help to ID this radio 11 tube Philco
I did R73 RCA. It has a phenolic board with all stuff mounted on it. And the wiring is deep under everything including ...morzh — 10:37 AM
48-482 rear panel help
Hi Keith, here is an article that covers different FM detector circuits including a section on the theory and alignment ...462ron — 08:26 AM
Well then Dan I guess this old man’s memory wasn’t too foggy :lolno: although I couldn’t remember where I saw that upgra...462ron — 08:08 AM
Fortunately, I did not have to do much to my GE S-22 (RCA R7A) Almost all caps and the 2 audio transformers packed into...MrFixr55 — 07:44 AM
Yup Arran is correct it is missing the pushbutton covers. I don't know where they all go but it's a common issue on this...Radioroslyn — 06:48 AM
I also have one of these, again it never had a back, and no trace of one. I have been told that the pushbuttons used to ...Arran — 03:29 AM
Thanks Joseph. Hope you get to restore your 48-482 before too long!keithchip — 02:12 AM
RCAs ain't no cake either.morzh — 10:32 PM
There are currently 643 online users. [Complete List]
» 1 Member(s) | 642 Guest(s)
