40-180 tube changes
You could also try subbing another 6J8. Unlusual, but could be in internal short.
(06-07-2015, 11:03 AM)codefox1 Wrote:  You could also try subbing another 6J8.  Unlusual, but could be in internal short.
I pulled the tube, and still had the voltage drop.
(06-07-2015, 10:40 AM)Patrick Wrote:
(06-07-2015, 10:11 AM)Radioroslyn Wrote:  After taking a second look I think I would unground that resistor. Circuit wise it doesn't make a lot of sense cause it will pull the plate voltage on the osc section of the mixer way down. Tube manual sez the triode section can take up to 250vdc which less than the chassis is providing. Is your 4.7K resistor in spec?
Yes. I'm going to keep this radio, So I've replaced all of the resistors, and checked the new ones as I install them. I'll go eliminate the possibility of a shorted socket first, then go from there with your second suggestion. But only after another cup of coffee. It's almost 8 A.M. here.
Tanks,
Pat
Ungrounding the resistor did the trick. However, now the pin 6 tap goes nowhere. It should go to the pushbuttons. But the ground where the 150 ohm was, is right next to a pushbutton connector. Even though the solder joint looks untouched, I'll bet the 150 goes there, and not to ground. Still doesn't show up in the schematic, but I DID find it in the production changes. Just says it's in series with the plate.
Just connected the 150 ohm to the pushbuttons, and VOILA. Problem solved.
Thanks everyone.
Pat
Philco 38-7 Speaker
I have let this one sit because of other duties. Now I am back, and I have a couple of questions. I hooked up a Hammond ...tludka — 05:34 PM
Philco 42-390, code 121 speaker
>>A closer examination of the very small print schematic indicates that the speaker is a PM type. This shows a ...morzh — 05:18 PM
Philco 60 Squealing
Litz is typically tinned by simply rubbing it with the soldering iron tip while immersed in solder (and a bit of rosin f...morzh — 05:14 PM
Philco 6K7
The suppressor grid (if by G3 you mean the S) is usually at the Cathode potential, which in this caes is GND. I am not ...morzh — 05:10 PM
Philco 16B Parts
Thanks for the reply. Unfortunately the radio was removed before bidding was over so I didn't get a chance to bid.dconant — 04:10 PM
Philco 16B Parts
Hi Dan, Mike is correct, there's a lot of painted stuff on the chassis but it looks pretty good. The sm is all there,sp...Radioroslyn — 03:50 PM
Hi Cap'n Clock, Unfortunately, I do not have this radio.  This is a shame because this should be a good performer.  2A...captainclock1988 — 03:43 PM
Using a 5W  1.5k  ceramic resistor in place of the field coil and using a 4 ohm PM speaker, I was able to bring the radi...Stevelog — 02:57 PM
Philco 60 Squealing
I have taken out the 2nd IF and found a problem or not. I believe the coils are litz wire. There is a very small strand ...dconant — 02:13 PM
Philco 6K7
I am restoring a Philco 37-60. The am reception is very good, but the shortwave is very weak. Run 6 Philco removes the g...bobbyd1200 — 01:35 PM
There are currently 4051 online users. [Complete List]
» 1 Member(s) | 4050 Guest(s)
