Philco 46-1226 code 125 HELP !!!
Threads: 11
City: Bellmawr, NJ
 Can use some help on this model Philco 46-1226 code 125,,,,Production Changes ,,,,Don't know the wattage for these's items,,,,,R102- 300 Ohms at 10 Watts (read on this site somewhere) ,,,,,R101-- 10K at ?? (10 Watts resistor?? screen supply) ,,,,R103-- 1300 Ohms at ?? (10Watts resistor?? B+ side),,,R100--265 ohms at ??? (1/2 watt resistor?? to chassis) ,,,R214--100K at ??? (1/2 Watt resistor?? output Grid Bias) AND,,,I'm sorry ,,don't know how to insert the schematic or page on here…Thank You again ,,Ken
Threads: 276
City: Wilsonville
State, Province, Country: OR
Threads: 11
City: Bellmawr, NJ
 That is a Code 121,,,,,I have that also,,,,not the same,,,,,I have a schematic from Chuck Schwark,,,code 125,,,,It does not have wattage on any resistors ,,,,and ,,I don't know how to figure that out,,,,just a good parts remover and replacement guy,,can read schematic's ,,but slow in doing soo,,Thank you for your time,,,Ken
Threads: 276
City: Wilsonville
OK, I was hoping Chucks docs had the run changes and wattages in them.
Threads: 270
Hi Ken,
Perhaps this will shed some light on this issue.
1.2 Resistor Dissipation
If the flow of current through a resistor increases, it heats up, and if the temperature exceeds a certain critical value, it can be damaged. The wattage rating of a resistor is the power it can dissipate over a long period of time.
Wattage rating is not identified on small resistors. The following diagrams show the size and wattage rating:
Fig. 1.3: Resistor dimensions
Most commonly used resistors in electronic circuits have a wattage rating of 1/2W or 1/4W. There are smaller resistors (1/8W and 1/16W) and higher (1W, 2W, 5W, etc).
In place of a single resistor with specified dissipation, another one with the same resistance and higher rating may be used, but its larger dimensions increase the space taken on a printed circuit board as well as the added cost.
Power (in watts) can be calculated according to one of the following formulae, where U is the symbol for Voltage across the resistor (and is in Volts), I is the symbol for Current in Amps and R is the resistance in ohms:
They don't show a 5w resistor but it is about the same length as the 2w but is a bit fatter about 9mm or3/8 "
Threads: 11
City: Bellmawr, NJ
Thank You,,,Terry,,,,  I have old Brown resisters in there ,,and I did find a picture similar to this in thee old models resistors,,,I would have though someone had all the stuff written down some where on thee old resistors wattage,,can't find anything on the old Philco numbers (on inter web) for resistors ,,BUT,,the ohms,, I guess I have to smoke it first to get it close, ,lololol,,  ,Thank you again,,,
Rogers Majestic R-646
By the way, the bypass you suggested is a rare solution in some circuits.
For example, this schematics solution is used...Vlad95 — 01:43 PM |
No, you are wrong, because you did not know the details.
Unfortunately, only ONE winding out of six is intact in both t...Vlad95 — 01:14 PM |
The output 45s are still in push-pull because the transformer secondary winding is still in the grid circuit providing o...RodB — 11:52 AM |
Thanks RodB for the help.
But this is not a real solution to this situation, not even a temporary one. Because the firs...Vlad95 — 11:34 AM |
I was going to check the voltages as you suggested and hooked it up to my dim bulb. It appears I have a short. The bul...bobclausen — 10:34 AM |
You can bypass the interstage transformer by disconnecting the primary, connect a load resistor of about 10k - 20k to th...RodB — 09:40 AM |
So, here's Prince on stage halfway through Purple Rain when he stoops down to his tech and says "Rod, pull out that...RodB — 09:17 AM |
Today I finished inspecting all the parts. The result is not very pleasing.
The first positive news:
1) The power tr...Vlad95 — 11:40 PM |
Well, found muh culprit. After using socket test adapters and finding voltages all ok, swapping 6V6s, no avail, swapped ...TV MAN — 11:18 PM |
Well, maybe - maybe not :lol: It's been an interesting project so far! Something so simple, yet so cranky. The 1st one ...TV MAN — 05:12 PM |
There are currently 967 online users. [Complete List] » 1 Member(s) | 966 Guest(s)
