Model 70 Speaker Problem
Several months ago I "rescued" a Philco Model 70 from a thrift store. I'm in the process of collecting a speaker, output transformer and other missing components.
A few days ago I purchased a Model 70 speaker with attached output transformer. Unfortunately, the field coil and primary winding of the output transformer appear to be open. (For guidance I'm using Ron's informative Tech Section article titled "The Speaker Problem in Early Philco Cathedrals.")
Has anyone repaired or rewound one of these field coils? I understand the center of the "pot" is pressed into the frame. I'd appreciate any advice (e.g., disassembly, technique).
A post on the Phorum states that replacement output transformers are available from Hammond. I'd prefer an original. As with the field coil, I'd welcome any advice on repairing or rewinding these transforms. Alternatively, has anyone used an individual or business that performs these services? Ron's Philco Resources mentions Heyboer Transformers. Is this cost effective or should I renew my search for a good used speaker and output transformer?
Allen Bell
Santa Barbara
Hi
An original audio output transformer for a Model 70 speaker that is still good is going to be rather difficult to find.
Having a transformer wound by Heyboer is not cost effective if you plan on "flipping" the set. If you really like the set and want to keep it, then yes, the expense is worth it. Heyboer does excellent work, by the way.
The field coil problem was recently discussed in another thread...
http://www.philcoradio.com/phorum/showth...p?tid=1465
Ron:
Thanks for your reply and the thread. The Model 70 is a "keeper" so I requested cost estimates from Heyboer and Tubes Tubes Tubes for rewinding the field coil and output transformer. I'll pass on the results.
Allen in Santa Barbara
PS: As a newcomer, I'd like to say "thanks" for all your time and effort. I've relied on your website countless times before and after purchasing my two Philco radios. (My other set is a Model 620.)
Arran, Thanks for checking you manuals. I appreciate that. Let me know what you find. PhilPdouglaski — 08:46 AM
I have some car radio service manuals, Riders I think (not to be confused with the big blue binders), so I may see if on...Arran — 01:20 AM
Philco model 40-100
Greetings; Here is an update, I found a listing on fleabay for a similar chassis to yours, and it has a photo of what...Arran — 12:58 AM
Philco model 40-100
Greetings; I think I may have found a clue as to what is missing, from a search I made, there is a rear view of the c...Arran — 12:12 AM
Philco model 40-100
I recently acquired a Philco model 40-100 farm (battery) radio. The radio was in very good condition except the red on f...mhamby — 05:59 PM
Hello, Richard the radio is an AC-2687 Studebaker model. The Philco model is S -5323 and the chassis p/n is S-5523Pdouglaski — 11:52 AM
48-482 rear panel help
The 48-482 is an AC only set as well, featuring a power transformer. While the transformer shouldn’t get “hot”, it is ye...jrblasde — 11:12 AM
I gave a Chrysler/MoPar car radio from 1954, it was made by Philco, and it uses two chassis, one has the power supply an...Arran — 11:06 AM
Hello keithchip. You could make a hardboard back for the set, but make sure you provide plenty of ventilation holes in ...GarySP — 11:04 AM
Welcome to the Phorum, Phil! Lots of friendly help here to assist you along the way! Take care, - GaryGarySP — 10:55 AM
There are currently 777 online users. [Complete List]
» 3 Member(s) | 774 Guest(s)
