Philco Phonograph
I have a Philco 48-1263 and am looking for service notes on the record changer in that set. I need to know the lubrication points. I'm betting the changer has not been lubed since Ike was in the White House.
Joe Connor
Hi Joe,
Chuck S. over at the Philco Repair Bench, will have the record player service data. Did that set use the D10 changer? If so, there is a whole booklet on it.
I wouldnt play it without taking it apart first and cleaning the old hardened grease off of all shafts etc. Alot of them used a plastic gear in the eject mode, that if everything is stiff, usually thats the part that will get stripped when you try and play it.
Yes, a D-10. He already got it over in ARF.
Ok - so I'm a little slow - I blame it on the temperature here in sunny WI - currently at 4 degrees!
Icon_surprised
I'm in sunny (3deg.) Evanston - on your doorstep, geographically speaking... 8)
I pulled the tube out and it's shorted from pin 1 to pin 2. I suppose that's the problem...sq65 — 08:12 AM
bob  Nice work on battery . If you don't. Have terminals i have a few spares  Samsam — 02:12 AM
hello mr Fixr, for sure !! I have some radios that I need to make some batteries for too. Sincerely richardradiorich — 12:33 AM
Dittos, sweet b on the battery. Love the "9 Lives" logo, remembered from my childhood. Other neat ones are t...MrFixr55 — 11:24 PM
Hi Morzh, Dunno if the AC EMI caps are an issue. I never liked the concept but never had an issue with these causin...MrFixr55 — 11:21 PM
And no hum without the 7AF7? Not common but I am thinking heater - cathode short. This would introduce hum in this sta...MrFixr55 — 11:14 PM
There are currently 1325 online users. [Complete List]
» 1 Member(s) | 1324 Guest(s)
