  • 1 Vote(s) - 1 Average
grill cloth woes
Hi guys,  I have a Philco 44 highboy that I restored a couple of years ago.  Getting ready to put in an order for some grill cloth.  What is on there now isn't bad at all but the cloth is heavy and the wrong pattern.  I would like to get as close as possible to the original.  Looking at Radio Daze inventory, would "GRC02" pattern be the closest?  http://www.radiodaze.com/grille-cloth/  I am having a hard time finding what the original pattern looked like.  There should be an attached pic of the radio.
Thanks
http://s350.photobucket.com/user/Don_Ray...sort=3&o=0
No one ever made an accurate pattern of the cloth which your 44H had originally.
That said...Kenny Richmond's "Whiskey Rayon" or the GRC02 from Radio Daze would be good substitutes.
http://richmonddesignsinc.com/grille_cloth_product_page
http://www.radiodaze.com/grille-cloth-02-item-grc02/
Thanks Ron, that is the one I was going for, just wasn't quite sure if that was the closest.
Welcome to the Phorum, Ken! The included schematic for your set is located in the Philco Library at the bottom of our Ho...GarySP — 03:13 PM
Video Source for Predicta
You can also source a used VCR and use that as a modulator to feed your DVD source into.TV MAN — 02:57 PM
52-942
Just received my 52-942. Its a handsome set. When I opened the back to examine it I noticed there are not connecting wir...Ken Arroyo — 02:54 PM
"Your radio tubes get these voltages from the power transformer secondary windings. The A voltage is supplied by th...osanders0311 — 01:40 PM
Please correct me if I am wrong, while working on this radio I noticed under the chassis where the bottom of the tubes p...osanders0311 — 01:28 PM
"BTW there's a 2.2k resistor from B+ to one of the XXL tubes so you have to identify those resistors before you rep...osanders0311 — 01:04 PM
BTW there's a 2.2k resistor from B+ to one of the XXL tubes so you have to identify those resistors before you replace t...RodB — 11:08 AM
Okey dokey, let's get on the wayback machine. Back when radios were running on batteries, they were powered by three DC ...RodB — 10:34 AM
Meter is a DMM (Brymen BM-257 to be exact) Voltage being measured to the chassis Yep, just double-checked 'emsq65 — 10:22 AM
Hi Peter, As for the spkr what you are looking for is a U-2 spkr. The H style spkrs are not as robust as the U models. ...Radioroslyn — 07:40 AM
There are currently 816 online users. [Complete List]
» 3 Member(s) | 813 Guest(s)
