Philco 70 volume issue
Link to schematic:
http://www.philcoradio.com/images/phorum/schem/70a.jpg
Ok, in this one it is #37.
The big wirewound resistor checks out.
So what did the result of post 10 turn out??
Now I think I've got it!
Radio off, volume at max, I read about 10 ohms from antenna clip to chassis......
....My socket voltages are close, except for the 2nd Detector. My plate voltage and screen grid voltages are about double what the printout states.
Well sounds like the ant coil is ok. As for the hv on the detector tube could be a high cathode resistor #24  51k or a weak 24A tube in that circuit.
There are currently 1557 online users. [Complete List]
» 2 Member(s) | 1555 Guest(s)
