Philco 38-5 Restoration Advice
I just had a guy drop off this beautiful 38-5. Probably one of the cleanest chassis I've seen yet (the photo is after a light scrub and wipedown) and it has something I've never seen before...it's original cardboard back.
[Image: http://i.imgur.com/eSdmMeJ.jpg]
[Image: http://i.imgur.com/4cnz8KD.jpg]
[Image: http://i.imgur.com/bT09zNM.jpg]
The cabinet is in great shape except for some topcoat crackle, the typical scuffing at the base and this ONE blemish.
[Image: http://i.imgur.com/2bmiHGa.jpg]
I'd like to preserve the original finish with some topcoats of fresh lacquer, but was looking for some advice on how I can better conceal that blemish. It looks like someone used some sort of epoxy (?) to fill a chipout. I was contemplating some sanding and topcoating, but I don't want to make it any more obvious than it already is. I've been burned "chasing problems" around before where I create a problem while trying to fix another.
Great looking radio!!
If it were mine...I'd probably leave it alone, but then I tend to buy radios that are in bad shape so that no matter what I do they are better off than when I get them Icon_lol
the card board back,,,is the money maker,,,,,
Any suggestions on how I can preserve that back? Are there any sorts of sprays or laminates that can stiffen and protect it? Maybe some clear epoxy spray?
would imagine clear coating it .
but I don`t think it would make it shinny as it would soak in
sam
I see nothing....
(07-23-2017, 09:00 PM)OldRestorer Wrote:  I see nothing....
Might be your browser.....
tgace
all your pic`s are gone
sam
It isn't Kirk's browser, I do not see any of your pictures either.
How about now?
Yes, thank you.
Shadow Meter Bulb
Model 28L
37-60 revision 6
Shadow Meter Bulb
Hickok AC51 tube tester
Model 28L
Hello, I'm restoring a Philco 28L and the output transformer is open. Part number of the transformer is 32-7020. Can...HORSTE — 10:32 AM
Philco 42-1008 conversion kit
I read about a kit to convert the variable speed changer in the Philco 42-1008 into a single speed unit.  That would rem...alangard — 09:30 PM
Tim Well...a chassis is metal. Magnetic or not, it does not matter. A transformer has some hum to it. It is natural. Th...morzh — 08:40 PM
I thought the 83 tube was bad because it looked white but it tests strong. Blue gassy though. I checked the fuse, it was...martinj — 08:37 PM
Shadow Meter Bulb
Ross I am not sure what current limiting effect the incandescent provides. They are two different parts of the sch...morzh — 08:31 PM
There are currently 6155 online users. [Complete List]
» 1 Member(s) | 6154 Guest(s)
