Philco 118 - Power Transformer Shorted?
This set fails the dim bulb test with the rectifier tube removed. Transformer primary measures 2.3 Ohms. I assume the transformer is shorted, correct?
Possibly but not necessarily. Did you remove all the other tubes also? There are lot of them and all the filaments combined will put a significant load on the transformer.
What wattage bulb are you using? The power transformer is pretty large and can draw appreciable line current.
Do you have a Variac where you can bring the voltage up slowly and see when the AC line current starts to increase?
Unless it is a short in the wiring to the transformer or between its secondary and the rectifier, I would say yes.
Yes it does matter what wattage you are using for a lamp. I assume you know what to use for the lamp.
Rob
It's a 100W bulb and lights brilliant immediately. I measured several of my large transformers and they all measure at least 5 Ohms. Owner reports "smoke and burning electronics" at last turn on. I called him after I posted this thread.
Bad short somewhere.
There are currently 1998 online users. [Complete List]
» 1 Member(s) | 1997 Guest(s)
