Philco 66 Faceplate
The bakelite dial faceplate on my Philco 66 cathedral version cabinet is missing and needs to be replaced.  Does anyone know if any of the other models use the same faceplate such as the 60, 38..?  Thanks for any help on this.
Hello. You might look at the 2 dials Radio daze has on their site. One dial shows it works for both 60 & 66 the other is a 66/ 66S/66X Don't know for sure which one you would need.
Here's the link.
http://www.radiodaze.com/dials-plastic-o...red&page=4
If by "faceplate" you mean escutcheon, then some 60 and 38 models use the same escutcheon.
Some 38/60/66 Bakelite escutcheons are small, later ones are large so you need the proper size for your radio.
That's a bit odd the dials for the 60 and 66 have different sw coverage. The 57 is a little bitty set wouldn't think it would fit at all. The three of these should have different dials unless I'm missing something. Must have the numbers mixed up.
He asked about a faceplate (escutcheon), not a dial scale. Two different animals.
Thank you all for your answers.. escutcheon is the correct word to use for it and what I need.  I think it is perhaps the smaller version but just not sure.  The screw holes in the case for it are very close to 1 3/4" center to center and the opening for it in the case is 1 1/4" high by 1 3/8" wide.  There seem to be a number of ones available for either the model 60 or 38 but very rare to see the model 66 version for sale.  Oh well.. just have to keep looking I guess.
I've started looking into the very weak and garbled reception in the set (I have the HS-62A version of the chassis seen ...klondike98 — 12:00 AM
Those last photos were not very good,so I  used one of my other cameras. This is more like the true colors of the radio....Dan Walker — 10:48 PM
If you look closely at the paper wax capacitors they probably have something like "outside foil" near the blac...RodB — 10:41 PM
Hello Dan, That really turned out very nice and I also like that color it is not to dark . I Have General Electric m...radiorich — 08:50 PM
Table radio 51C or 52C?
The model 51 and 52 are identical mechanically, I'm not sure what may have been changed between the two chassis but one ...Arran — 08:18 PM
Well today I  installed the grill cloth board and the speaker.  The speaker must weigh 20 pounds by itself. I put the c...Dan Walker — 08:10 PM
Unidentified Philco Bakelite
It's a British Philco, likely from the early 1950s. It has a very common layout for British sets starting in the post wa...Arran — 08:02 PM
I suggest you take that look under the hood eventually. Makes little sense to try to figure things out without looking ...morzh — 07:03 PM
Possibly a UK radio. I make this presumption based on the Long Wave band. A photo of the back available? Take care, -...GarySP — 06:18 PM
Morzh There are only 7 wires coming off the transformer. 3 for B+, 2 for 115 in and 2 for 5V to the 80. Maybe there i...antiqueradionut — 05:36 PM
There are currently 345 online users. [Complete List]
» 1 Member(s) | 344 Guest(s)
