Threads: 20
City: West Milford NJ
I had recently did a recap on a 46-1209. I still have a slight humm but if I wiggle first 6v6 after the 5y3 the humm stops and when I let my finger off the humm comes back. I have replaced both 6v6gt's. and my radio still don't work but the phono plays strong.
Threads: 574
1. What do you exactly mean by "wiggle"?
2. You let your finger off of what exactly? Glass?
3. What does "don't work" mean? Humming but playing / not playing and humming....what? From your topic subject first I thought it is humming while playing.
Could you be a bit more specific and less ambiguous?
Threads: 20
The phono works no radio if I push on that tube either base of glass the humm goes away until I take my hand off the tube.
Threads: 270
Sounds like you've got a bad connection. Would clean the tube sockets and double check any connections made to ground though a rivet. Break out the solder flux and resolder the grounds.
