philco 1939 907t rp
hey guys
I have a 907 rp
it is suppose to be wireless .
but I don't see any wire inside like others have inside
I replaced caps but duhh I noticed this one how do I find out what it is
says  30-2202  or 30-2292  I checked it`s dead no value at all
also  their are connectors  # 1 and 2  and red and black
has a radio/ phono switch  tested both no power and used pm speaker nothing
I should hear some thing around 55.1 for wireless
sorry but their is no schematic  for it
I found a 30-2292 in the '36 parts catalog. It's listed as a 12mfd @450v. Didn't list the 30-2022. Where is it connect??
Not surprising it only makes rf no audio.
Measure the voltage from pin 8 of the 6X5 to chassis. Should see 150-200vdc.
Hey terry
Box you say is 12 mf is on 6j5 pin 8
I put a 22 in temp  still nothing for wireless
I have 168vdc on 6x5 pin 8
Thanks sam
Ok if it's on pin 8 of the 6J5 the voltage is low there like <20v. Doesn't require a 450v unit. The high voltage is working so let have a look at pin 3 of the 6J5, pin 3 of the 6K7 and pin 4 of the 6K7. All of these should have some hv present. Would check the oscillator coil for continuity. It probably has 4 connections  with 2 winding so two pairs should have continuity.
terry
here`s voltages
thanks sam
Voltages look good and there where their suppose to be.
The coil, is it connected to the 6K7 or the 6J5?? To me it
would make sense to be connected to the 6K7. Just wanted
to check. What's the voltage on the 6K7 cap? Should a
little -.
We also don't know what frequency it's tuned to, it may
be working but your not listening for it @ the frequency
it's transmitting on.
Happy hunting!!
Sam
I checked the 1939 Philco RMS Year Book for you, and this model is not even mentioned in there...sorry Icon_sad
thanks terry
will scanning higher
no problem ron
only found crappy pic on RM
so close yet so far Icon_cry
terry
6k7 is dead zero with or with cap removed
nothing on wire or tube
did get very low sound at 944  very little adjustment  944 to 970
I know cart is bad used 2 known good ones still very low sound
is their some place I can connect a wire for antenna
thanks sam
>Is their some place I can connect a wire for antenna?
Would look for a connection from the coil over to one of screw terminals on the bottom. It also could be a connection from the coil thru a small cap to one of the screw terminals.
Greetings Phorum members, Hope you can help me identify this type of wire in the photo I have attached.  I am not sure ...georgetownjohn — 01:53 PM
Philco 60 Squealing
Philco 60 Squealing
Philco 42-1008 conversion kit
12' Philco
Shadow Meter Bulb
Shadow Meter Bulb
Model 28L
There are currently 4062 online users. [Complete List]
» 1 Member(s) | 4061 Guest(s)
