Cabinet colors???
I have a 40-190 that needs refinished and need some help with toned lacquer color selection. The lacquer on the solid (non-veneered) sections is slightly opaque. Does anyone know what Mohawk lacquers to use? Has anyone ever put together a color chart for old radios? Thanks
Every 40-190 I have ever seen has been toned Medium Walnut overall.
http://www.philcoradio.com/gallery/1940a.htm#ae
The photo in my site's Gallery shows a 40-190 with an excellent original finish. The wavy appearance on the right side was just a reflection.
Quote:Has anyone ever put together a color chart for old radios?
There are way too many vintage radio cabinets out there for any one person to take on such a monumental task. Someone, or a group of people, would have to be independently wealthy to tackle something like that because it would take years of daily work to research and complete.
Just my 2 cents worth.
Mohawk sells two different lines of toners. One is a dye type that is good for general translucent shading and the other is a pigment type that is fairly opaque. That's the one you usually want for end or bottom pieces.
As for colors...well, you can imagine the problem since the colors have changed over the years even on a perfect set kept in a time capsule Icon_smile Generally the 'walnut' versions do the trick. Some people like Van Dyke Brown and/or Perfect Brown but I find them to be a bit TOO off color from walnut.
I have some car radio service manuals, Riders I think (not to be confused with the big blue binders), so I may see if on...Arran — 01:20 AM
Philco model 40-100
Greetings; Here is an update, I found a listing on fleabay for a similar chassis to yours, and it has a photo of what...Arran — 12:58 AM
Philco model 40-100
Greetings; I think I may have found a clue as to what is missing, from a search I made, there is a rear view of the c...Arran — 12:12 AM
Philco model 40-100
I recently acquired a Philco model 40-100 farm (battery) radio. The radio was in very good condition except the red on f...mhamby — 05:59 PM
Hello, Richard the radio is an AC-2687 Studebaker model. The Philco model is S -5323 and the chassis p/n is S-5523Pdouglaski — 11:52 AM
48-482 rear panel help
The 48-482 is an AC only set as well, featuring a power transformer. While the transformer shouldn’t get “hot”, it is ye...jrblasde — 11:12 AM
I gave a Chrysler/MoPar car radio from 1954, it was made by Philco, and it uses two chassis, one has the power supply an...Arran — 11:06 AM
Hello keithchip. You could make a hardboard back for the set, but make sure you provide plenty of ventilation holes in ...GarySP — 11:04 AM
Welcome to the Phorum, Phil! Lots of friendly help here to assist you along the way! Take care, - GaryGarySP — 10:55 AM
Hi Pdouglasti, Phirst off, welcome to the Philco Phorum, a Phamily Phriendly place phull of phun pholks and all things ...MrFixr55 — 07:37 AM
