10-15-2018, 09:04 AM
Hello experts,
My tone arm on the BOL has dim brightness on the bulb. I have used other NOS bulbs and get the same result. I believe the chassis has the adjustment screw turned up all the way also. I have used new wires from the socket to the chassis that are slightly higher in thickness, could that be the cause or any other suggestions? When I use a #55 bulb, which is similar but not correct, it is brighter, but not good on the sound reproduction, I like the original bulbs better. On my 1942 -1008, no such issues, seems strange. Any suggestions?
