41-295 I.F. Transformer Caps Missing
http://www.nostalgiaair.org/PagesByModel...013423.pdf
Have the 3rd I.F. can, part #42 open. Suspected open coil, but it is OK. Schematic shows two 100mmfd caps inside, #'s 42A and 42B, and #42C, a 47K resistor. The resistor is there but no caps.The black wire that grounds the two caps just dead-ends at pin. Does anyone know if this was a production change? If so, why did they leave the wire ? 99% sure radio left factory like this. I don't know enough to determine what  effect  this would have on circuit.
The 100 pF caps are built into the white ceramic piece at the top of the IF transformer, so they are not visible.
OK,thanks. Curious. Are they under the variable or actually cast into the ceramic?
New Philco Repair Bench
Morzh is correct. The repair bench on our website is an archived image of chuck’s original site. He no longer provides s...klondike98 — 05:32 PM
Excellent information. It is all starting to come together now and your explanation really helped since I noticed that ...georgetownjohn — 04:39 PM
Hi John, I don't have this radio, but I can supply some info: Based on your pic, pins 7,8 and 1 are used together, go...MrFixr55 — 02:02 PM
As far as I know, the Repairbench does not work, and has not been working in a while. Chuck (we had that campaign looki...morzh — 01:33 PM
Radio city products 664 schematic request
Need a schematic or manual for the 664. The 663 may be similar.daveone23 — 12:38 PM
Thanks Gary.dconant — 12:16 PM
I tried accessing the site through our library and got the same response. It's reported to our tech gurus. GaryGarySP — 11:50 AM
I'm not sure why that wire wasn't covered in the video. I'm pretty sure the 6A8 won't work until that pin is grounded. Y...RodB — 09:47 PM
There are currently 6081 online users. [Complete List]
» 1 Member(s) | 6080 Guest(s)
