Grill Cloth for Philco Model 51B Cathedral Radio
Threads: 4
City: Orlando
State, Province, Country: FL
Hello, I am trying to locate grill cloth similar to the pattern in the attached photo. Any assistance is much appreciated. Thank you.
John [url=https://mail.aol.com/webmail/getPart?uid=AFlb9goAAAERWtX-BwyqMExQ1pk&partId=2&saveAs=DSC01494.JPG&scope=STANDARD][/url]
Image(s)
That isn't the original cloth used in the 51B.
The original cloth looks the same as the cloth used in models 70 and 90, as well as most other Philco cathedral radios made from 1931 - 1933.
Radio Daze:
http://www.radiodaze.com/grille-cloth-02-item-grc02/
Threads: 4
City: Orlando
Ron , Thank you for the quick reply. I apologize for stating the incorrect model number. The photo on the tube shield states models 51 or 51A. I think the grill pattern is called a centered "drape" pattern .
If this exact pattern is no longer available, can you suggest one that would be appropriate for this model?
Thanks again,
John
I already have in post #2, this thread. The cloth you have is old, but is not original to the radio.
Threads: 291
City: Wilsonville
State, Province, Country: OR
The Radiodaze link Ron posted is the grill cloth you want. Welcome to the Phorum!
Threads: 4
City: Orlando
I’m very surprised to learn that it is not the original cloth. It appears to be made for this radio as the pattern sweeps from the center of the opening. It is at least 60 years old, as it has been the same since I was a child. I’d like to continue to use it, but unfortunately it has a tear, that I do not think can be repaired.
Thanks for the information.
John
John
I wasn't (and am not) trying to be mean, really. I was simply pointing out a fact - the cloth you have is
I did mention that
Quote: The cloth you have is old, but is not original to the radio.
Given that your 51B is 86 years old, it is quite plausible that the original cloth could have been replaced with what you now have 60-75 years ago.
That cloth looks like either an RCA (also C.G.E in Canada) but I think some Brand Z models also used similar stuff.
Threads: 4
City: Orlando
Thanks Arran. I would really like to find the same pattern, but I don’t think I will.
John
Threads: 33
I have a couple of Canadian-built RCA Victors that use that cloth.
I know that one of mine does for sure , it's an RCA-Victor 95T2 from 1939.
Hello Roy,
sincerely Richardradiorich — 12:45 AM
Richard,
Had grabbed it already but thank you just the same. I find myself wanting to find some way to block out the...glyphmon — 12:03 AM
Hello roy,
Sincerely Richardradiorich — 11:54 PM
Richard,
The Silvertone 2014 also is a transformerless set, so I am incorporating a 1:1 600 ohm audio isolation transfo...glyphmon — 11:37 PM
Did an alignment today which was interesting. IF alignment went great, almost all was already spot-on. Adjusting on th...glyphmon — 11:35 PM
While I'm waiting to wrap up the final steps on my wife's Silvertone 2014, I started disassembly on the next project. O...glyphmon — 11:07 PM
Hello roy,
Sincerely Richardradiorich — 10:50 PM
Safety caps arrived today. Soldered one in and had a successful first power-up. No magic smoke escaped and it tunes in...glyphmon — 09:53 PM
