Philco 38-690 Troubleshooting.
I am working on a Philco 38-690.
Can I test and troubleshoot the power / audio chassis WITHOUT connecting RF chassis to it?
Thank you,
nv3g
Oscar
http://www.nostalgiaair.org/pagesbymodel...013255.pdf
If you look at the circuits in this radio, both power supplies are needed for the audio amp. The bottom one supplies the current for the driver and finals, and the top one supplies grid bias to the amp and B+ to the receiver. So you’ll need both power supplies running and all speakers hooked up to start with.
I don’t know what the bias voltages would be like with the top power supply not properly loaded. I suspect not correct. If that question could be answered by someone how did exactly what you want to try, we’ll know if anything will get damaged.
I get that it would keep the bench less cluttered while working on it. Other than that, not sure what would be gained.
Tony
Nice job on the battery, Bob. Can the box be opened to replace the 9 volters?RodB — 11:32 AM
Thank you for the detailed response MrFixr. To clarify, the hum starts when the tubes are fully warmed up, and goes a...sq65 — 09:15 AM
MrFixr The chassis, if there is no ground pin in the AC plug, due to the Y-caps from L/N to the chassis, is at 60VAC re...morzh — 08:47 AM
schematics
thanks I'll try the polar caps seperatelymseno — 07:38 AM
Hi SQ55, A strange issue indeed!  Just so I have you straight, on a dim bulb you get normal operation after the set warm...MrFixr55 — 12:44 AM
schematics
I think mseno is talking about cap# 27 which is a multisection but in a paper tube. In cases like that I've usually be ...klondike98 — 11:25 PM
schematics
Ohrenet  :roll: For their price I would chase a fly in a field.  :twisted:Vlad95 — 11:21 PM
A bit more work on the Motorola. I got the repro battery together right up until I realized the snap clips on the top o...klondike98 — 10:45 PM
schematics
Often restuffed. If a twistlock, Hayseed Hamfest makes modern replacements. morzh — 09:18 PM
schematics
Looking for a multi-sectional 8+16 mfd cap. Can't find any suppliers that carry it.mseno — 08:45 PM
There are currently 1243 online users. [Complete List]
» 2 Member(s) | 1241 Guest(s)
