Record Blanks for 1941 Philco Beam of Light Record Cutter
I'm restoring a 1941 Philco Beam of Light 78 rpm phonograph (Radio/phono Model 41-608) with the optional HR-1 record cutter (uses a X-26 crystal cutter cartridge with steel cutter stylus). I've had the playback tone arm and record cutter cartridge rebuilt by Gib at West Tech; I've repainted the changer; and now I'm starting to work on the mechanism.
I need a source of blank discs to test the record cutter and for general recording use. I see PVC and polycarbonate blanks for sale at about $3.50 each which is not a bad price.
However, are these the correct ones to use with this cutter? Is one type better than another for record longevity and/or ease of cutting?
I worry that the PVC or polycarbonate may be too soft and the heavier tacking of playback tone arm may destroy the recorded PVC/polycarbonate disc after a few plays.
Does anyone have any experience with this and can they recommend a source for a good, economical source for the correct type of record blanks for this type of cutter and application? After reading several posts on potential issues with NOS blanks, I prefer not to go that route if possible.
Scott
There are currently 1901 online users. [Complete List]
» 1 Member(s) | 1900 Guest(s)
