Chassis protection for a 650
I got stuck on this project it's waiting for more ambition. Can't seem to make the trim pieces for the front and corners.
I wanted some protection for the chassis.  The idea is to keep the cabinet as small as possible including the speaker.
On the face   The space on the left of the cardboard strips is for the speaker grille. I wanted to use the little speaker that is on top, But I couldn't bring myself to separate the original one.  I noticed that the output transformer has different taps for the speaker coil. I should be able to match the impedance close enough to run the small one. The big one can just go for the ride.
The strips are to be wood trim. The steel plate that holds the big speaker has a hole in it.
I found the display window on ebay.  Did I get the right one?  The shadow meter window was blocked so I used scotch tape for the meter display screen. That's why it's white in color.
I think some green tint might look good. Make it look like an eye tube.  And it's off center again.
It was tricky getting all those little arrows to line up with the dial.
Here's the link to the electronics thread      https://philcoradio.com/phorum/showthread.php?tid=19767
LOL!! Well Arran, if you do dive into it and come across any advice on dealing with accessing components let me know. I...klondike98 — 11:56 PM
Bob and Gary; I have the further complication on the Phillips that they decided to use some 200 volt rated paper caps...Arran — 10:05 PM
Thx Arran & Gary. Yes its super crowded in the chassis and I've debated whether to try to restuff caps or not. I t...klondike98 — 07:40 PM
That's got to be one of the tightest conglomeration of components I've ever seen! I wonder how the line workers felt bu...GarySP — 05:46 PM
Bob; I think that the Phillips was actually manufactured in Canada, though they may have imported many of the compone...Arran — 02:28 PM
I've started replacing the electrolytic caps now. As Arran mentioned, they are housed under a metal strap. Here's a ph...klondike98 — 12:22 PM
Thank for that info Arran! Very interesting. Phillips and Motorola must have made some type of marketing deal back then....klondike98 — 11:49 AM
46-1213 Schematic Question
Good idea on the fuse. These old transformers need extra protection.RodB — 10:02 AM
Hello Larry, Well, anyway I can contest about noisey grounds in my living room when I am using one outlet in my house a...radiorich — 08:03 AM
RodB & MrFixr55, Thank you both for the great replies at my questions, I appreciate the help very much.  As suggest...MissouriLarry — 07:04 AM
