40-180 Start up & volume problems
I have recapped this radio and it does play. it takes a minute to hear any sound and the speech is not clear and volume slowley increases in about three minutes. The speach clears up and volume is ok. This set uses a 1232(RF), 6J8(Det, Osc),(7B7 ) IF, 7C6(1st Audio), 84(Rect) and 2(41 output tubes). The radio motorboats on the shortwave band and seems to get faster as I go up the dial. Could one or more of the tubes be the cause of the problems or is it something else? Thans for any help..radionut
Just hang on you,ll start receving answers from alot of experts . I think reason you haven,t because of power outage some places.
Denver: Thanks for the words of encouragemant. I shall be eagerly be awaiting the responses. have a wonderful rest of the week!
Could be a tube or tube shield not in place. More likely a missing bypass capacitor.
Now I think I've got it!
None of the 40-180s (or 40-190s, for that matter) I've seen have tube shields, so that isn't a likely case.
There are currently 2266 online users. [Complete List]
» 1 Member(s) | 2265 Guest(s)
