37-116 - Installing Grill Cloth - How?
I'm trying how to install grill cloth for my 37-116.
I don't particularly want to glue it where it would be visible in the center opening in the cabinet. But, I'm not sure that's possible. The cloth will pass over the two, side, "clarifiers" where there's no surface to glue it to. The original cloth has the chevron pattern repeated on the sides so it could be simply be glued along the edges of the board. I roughly outlined the center opening in the photo so I can sit here at my desk and stare at it...
Any suggestions would be appreciated. I've actually thought of putting a piece of wood across the clarifier openings to give me something to glue it to. Looks like the clarifiers are covered some by the cabinet anyway.
Greg
Greg O.
Whitehall, PA
Philco model #20
AHH HA , I got it and can’t thank you fellows enough , when I changed the capacitors I took the advice and did not unsol...onlyrick — 02:24 PM
Hello Ed, yes, I like letting projects run for few days to make sure they don't start acting up . Sincerely Richardradiorich — 01:03 PM
I am almost finished with this restoration. All which remains is the power transformer. I cleaned it up some time ago, b...jrblasde — 12:41 PM
Philco model #20
I seem to recall in some TRF sets there being a Local/Distance toggle switch that removes the B+ from the first 24 rf tu...RodB — 09:46 AM
Refinishing Ideas
Hi Doppelganger, After rereading your thread, did you mount the Zenith speakers in the two bottom left and right pos...MrFixr55 — 09:39 AM
Philco model #20
Hi Rick, One other thing regarding volume on this set.  Make sure that the tube shield is in place.  this is that la...MrFixr55 — 08:22 AM
Philco model #20
Hi Rick, The volume control on the Model 20 has 2 sections and does 2 seperate things: One part of the control, ...MrFixr55 — 10:30 PM
Philco model #20
Hello again fellows , well I powered up the set this evening after I had changed every cap and resistor in this set and ...onlyrick — 09:34 PM
Yes - better it happened on the repair bench than returning to the owner. The other question is - do I also dissect a...EdHolland — 09:08 PM
That's a bummer but get them now. Paul BPaul Philco322 — 08:27 PM
