Line Cord Replacement
What is the recommended connection when replacing a non polarized line cord with a polarized line cord on a 46-1209 chassis? I have the hot side connected to the bakelite terminal where the brown wire to the on tone control is connected. What difference does it make?
If there is a contact that potentially goes too GND/Chassis, I connect it to the wide one (Neutral).
But it is not really important.
When I run into this situation, I usually connect the hot side to the switch and rewire the cap block to the other side of the switch. This way, the safety caps don't get power till the switch is on and the transformer primary won't be hot when the switch is off.
Rod
I've seen AA5 units whose switch is in line with the chassis.
Yes, I have one on my bench right now. If at all possible, I'll add a polarized plug and move it to the hot side. Some are easy, others more challenging.
Most if not all Philco AA5 sets were made with the switch in the neutral (B-) side of the line.
When I work on these, I also move the switch to the hot side of the line, and use a polarized plug as well.
I wonder what the thinking was behind it.
I like the idea of moving the cap block to the other side of the switch so that the power is not on the transformer until the switch is made. That, and I have wired the hot side of the polarized plug to the switch. Thank you, gentlemen, for your comments and advice.
Hi Folks,
Yes, almost any AA5 I have ever worked on has the power switch on the "chassis" (B-) side of the line.  My best guess is that reason for doing so was to keep the switch, usually mounted on the volume control at a low potential to cut down on hum.  Voltage-wise it makes sense, current-wise, not so much.  Safety-wise, it makes absolutely no sense.
Most "hot chassis" sets connect the chassis to the power line through a cap or cap with a high value resistor in parallel.  However, some (my Emerson 330 for example) has the chassis wired directly to B-, through the power switch.  The chassis mounting bolts are accessible from the bottom of the radio, and the back, of course, is missing.  The plug in one direction could make the chassis hot with the switch closed.  the plug the other way has chassis at ground potential with the switch closed but hot, through the heater string, with the switch open. Icon_e_surprised
My RCA 8X71 AM-FM is the same way, but at least there is an interlock and no chassis screws protruding.
I always modify any AA5 set that I work on to put the switch on the hot side and the neutral (Wide prong of plug) to the B- side.  On a true hot chassis, it may be a good idea to isolate neutral - B- from the Chassis using a 0.1uF cap with a 250K resistor in parallel from Neutral-B- to the chassis.  This provides a path for RF (the Tuning Cap frame is usually grounded to the chassis) and prevents hum from the chassis floating.
In the rare case when placing the switch on the hot side instead of the neutral side produces too much hum and lead dress or shielding does not resolve, leave the power switch out of the circuit and install a switch in the hot side of the Line Cord.  Yeah, not factory, not authentic, but safer.
On transformer powered sets, use safety caps, one across the transformer after the switch, the other between chassis and neutral (wide prong on plug)
Hello Guys,
Yes I agree I have a model 53-930 on my bench right now and yes the the power switch on the "chassis" (B-) side of the line As MR Fixr said .
I will change the wiring also add a fuse inline and add Safety capacitors too.
There are currently 1739 online users. [Complete List]
» 1 Member(s) | 1738 Guest(s)
