Philco 90 Capacitor 28
I am working on a Philco 90. Capacitor 28 has three capacitors, .5 ufd, .25 ufd, and .25 ufd. The schematic does not give the values and I would like to know which one of the capacitor symbols is the .5 ufd capacitor on the schematic?
Thank you,
nv3g
Oscar
There are several versions of the 90. Ron has annotated these schematics, does this help?
Early Version (2 45tubes)
Middle version (1 47tube)
Late version (2 47tubes)
Yes, thank you!
Icon_thumbup Icon_thumbup
Thanks!!!!!!  I am restoring an early 90. I rebuilt the 28 cap and needed to know which went where.
Bob
Philco model #20
AHH HA , I got it and can’t thank you fellows enough , when I changed the capacitors I took the advice and did not unsol...onlyrick — 02:24 PM
Hello Ed, yes, I like letting projects run for few days to make sure they don't start acting up . Sincerely Richardradiorich — 01:03 PM
I am almost finished with this restoration. All which remains is the power transformer. I cleaned it up some time ago, b...jrblasde — 12:41 PM
Philco model #20
I seem to recall in some TRF sets there being a Local/Distance toggle switch that removes the B+ from the first 24 rf tu...RodB — 09:46 AM
Refinishing Ideas
Hi Doppelganger, After rereading your thread, did you mount the Zenith speakers in the two bottom left and right pos...MrFixr55 — 09:39 AM
Philco model #20
Hi Rick, One other thing regarding volume on this set.  Make sure that the tube shield is in place.  this is that la...MrFixr55 — 08:22 AM
Philco model #20
Hi Rick, The volume control on the Model 20 has 2 sections and does 2 seperate things: One part of the control, ...MrFixr55 — 10:30 PM
Philco model #20
Hello again fellows , well I powered up the set this evening after I had changed every cap and resistor in this set and ...onlyrick — 09:34 PM
Yes - better it happened on the repair bench than returning to the owner. The other question is - do I also dissect a...EdHolland — 09:08 PM
That's a bummer but get them now. Paul BPaul Philco322 — 08:27 PM
