Philco 95 Dial Cord Help
Good morning. I'm working on a 95 low boy. Does anyone have dial cord restringing info ? Thank you ,Bill
https://philcoradio.com/phorum/showthread.php?tid=3531
Now I think I've got it!
In case you ever work on something other than Philco radios, try this
[admin note: link was deleted because malwarebytes detected a trojan virus]
Sometimes I wonder whether the world is being run by smart people who are putting us on or by imbeciles who really mean it.
Thank you Terry, good to hear from you !!!
Hi Bill,
Just as a side note there's a hand full of chassis that use that same setup. The 76,77,87,95, and 96 come to mind.
Good luck it's a bit of a pain...
Back to the 660L 770AM.
Thanks Terry. Is it possible to use regular dial cord on these ?
You can try it but it's got to be really tough. You have some of the original right? It's metal cable. Just to give you an idea what Phico used.
If your 95 is similar to the 514 I restored you might be able to use a flexible, light picture hanger wire. It's a little stiffer than the original but it worked fine.
Thank you Rod, I'll check that out . Best regards , Bill
