speaker replacement
I have a Wards 1942 Airline radio model 14BR-1109A. It has a 12 inch speaker that should be replaced. The only info I have is a P/N BE114261 T9. It is also marked 200ohms.
Does anyone know of a replacement?
Thanks.
So what did your P/N BE114261 T9 come out of? Is the original speaker missing?
Got your pm and if your could post a pic of the spkr and small tear it would be helpful. You will probably have to downsize the pics to meet the phorums size requirements.
Tnx
[attacGreetings,
Attached are photos of my Wards speaker. Any help would be greatly appreciatedhment=27349]         [Thanks,Mike                         attachment=27351]
I've seen worse. If the voice and field coils are good, a little rubber cement and tissue patches on the surround should fix it. Also a felt disk to protect the gap between the voice coil and magnet pole.
Agree 100%. Also, for what it's worth, it looks like a 1940 Philco speaker...
Thanks s to all of you! I will try your fix.
5U4 vs 5Z4 tubes
5U4 vs 5Z4 tubes
5U4 vs 5Z4 tubes
5U4 vs 5Z4 tubes
There are currently 1111 online users. [Complete List]
» 2 Member(s) | 1109 Guest(s)
