Philco 3650/650 Tuning Mechanism
Hello, I need to dismantle the tuning mechanism in my 3650 (Canadian). I have removed the dial screen but can't figure out how to remove the shadow screen. The picture shows how far I have gone. Also the band selector has a set screw (red circle) that seems to be fused in place. Tried Liquid Wrench having no luck.
Dan
Perhaps this will help  Dial Drive Rebuilding – Models 116, 640, 643, 645, 650, 651, 655, 660, 665 – Philco Library (philcoradio.com) Some set screws can be tough to remove. A good fitting screwdriver is a must with straight blade not rounded on the corners. You can try holding a hot soldering tip on the offending screw. I'm pretty sure that the part is mostly pot metal so if you want to use a torch be careful not to melt it.
Thanks Terry. The link was just what I needed. I'll give the hot soldering iron a try.
Dan
Just as I thought I am missing the dial pointer shield. Any idea where I can get one. Did not find one at Radio Daze. Mine would have 4 arrows.
Arran, Thanks for checking you manuals. I appreciate that. Let me know what you find. PhilPdouglaski — 08:46 AM
I have some car radio service manuals, Riders I think (not to be confused with the big blue binders), so I may see if on...Arran — 01:20 AM
Philco model 40-100
Greetings; Here is an update, I found a listing on fleabay for a similar chassis to yours, and it has a photo of what...Arran — 12:58 AM
Philco model 40-100
Greetings; I think I may have found a clue as to what is missing, from a search I made, there is a rear view of the c...Arran — 12:12 AM
Philco model 40-100
I recently acquired a Philco model 40-100 farm (battery) radio. The radio was in very good condition except the red on f...mhamby — 05:59 PM
Hello, Richard the radio is an AC-2687 Studebaker model. The Philco model is S -5323 and the chassis p/n is S-5523Pdouglaski — 11:52 AM
48-482 rear panel help
The 48-482 is an AC only set as well, featuring a power transformer. While the transformer shouldn’t get “hot”, it is ye...jrblasde — 11:12 AM
I gave a Chrysler/MoPar car radio from 1954, it was made by Philco, and it uses two chassis, one has the power supply an...Arran — 11:06 AM
Hello keithchip. You could make a hardboard back for the set, but make sure you provide plenty of ventilation holes in ...GarySP — 11:04 AM
Welcome to the Phorum, Phil! Lots of friendly help here to assist you along the way! Take care, - GaryGarySP — 10:55 AM
There are currently 777 online users. [Complete List]
» 3 Member(s) | 774 Guest(s)
