Threads: 15
City: Monticello
State, Province, Country: Illinois
I just picked up a Kiel Radio Table with a model 55C chassis in it. Does anyone know who to tell if it's a late model or an early model? I have found drawing on but some of the voltage test points are different, so I think I need to figure it out, so I know which drawing to use. Although there are not too many differences between the two it appears. Can it be broken down based on the serial number?
Threads: 266
If you are a FB member there's a group for that.
Threads: 266
I see from the replies you've gotten on FB there's no definitive answer to your question. A lot of changes though a production run for any number of reasons go undocumented. In the early '30s cost could be a good motivation or better performance.
GL w/your AK and may your transformer failures be few.
Threads: 8
City: S. Dartmouth
State, Province, Country: MA
Here is a discussion of the changes:
https://antiqueradios.com/forums/viewtop...=6&t=70452
All links are now dead. Try web archive for a copy of the entire atwater-kent web site.
etorre, an ARF member is currently restoring an A-K 55.
Chas
Pliny the younger
Threads: 15
City: Monticello
Threads: 268
City: Bandon
State, Province, Country: OR
Here's the
thread for the table and radio restoration I did a few years back in case its helpful for you...
