Need Help to ID this radio 11 tube Philco
Hi Everyone,
New member but have been reading this for awhile for tips!
Vaccum tubes were before my time so bear with me on my ignorance!
I'm just an old DeVry Phoenix grad from the beginning of the digital age. We had to fix everything back then.
I worked for Fairchild Systems and then 42 years Tech Service for same company. Systems and industrial controls.
I just completed a 46-350 and it got me interested again in doing a Tombstone I was given many years ago.
It was barn/shop find and had a few things living in it.
I don't know how to ID the model number since the label part with model # is torn off.
It is a 11 tube Philco.....By looking at the components I'm guessing mid or earlier 1930's?
I enclosed pictures of the cabinet, dial and labeled the tubes I could get to without disturbing the brittle wires.
It's not to bad underneath, has been worked on - (1960"s)? a couple caps/components replaced.
I can't read some values because they black taped Caps together and paper on Cap's is peeling off with tape. So I will need to locate a schematic.
I have never put power to it. It will need some work before that happens.
As you can see that 1 of the #8 tubes top wire is broken off and It's missing one of the knobs
Dial has 4 scales. Darn thing weighs about 40 lbs.
If anyone can point me in the right direct I will really appreciate it!
Thanks
Ken
It is a 16B tombstone.
Thank you.
I went to your online library and found 2 schematics.
I will download and compare to components!
Welcome to the Phorum, Ken! Lots of help here for all of your restoration questions. Take care and BE HEALTHY! - Gary
Yes the 16B as morzh pointed out. Specifically its the January 1935 model version of the 16B. There are a couple earlier versions of it as well. One built in the fall of 1934, one in June of 1934 and lastly one in June 1933.
Welcome,
the radio looks intimating 11 tubes, wish you well.
Jim
Spring Lake MI
Here you go:
https://philcoradio.com/library/download...%20205.pdf
Your the code 125
Philco 16 is not intimidating at all. Despite being an 11-tuber.
37-116 is indeed intimidating.
16 has good space underneath and so allows to work without major hassle. Some 16B have a tin can filter caps assembly, and this is a but inconvenient, but the one you have is not likely to have it.
All in all it is not 16 (have 4 of them, 3 restored by me) that would be my nemesis. Not even 37-116.
In fact some measly Zenith Transoceanic is way less convenient to work on.
If you want a radio that's difficult to work on, get a 37-620. The one side of the chassis is packed pretty tightly and deep, not to mention the separate RF chassis. I still have one on disassembled on the work bench for an embarrassingly long time (busy with other stuff also).
Greg O.
Whitehall, PA
I remember Philco 45 being awkward. If I am not mistaking it for some other set. I think there is a phenolic board, or even two of'em with bunch of parts on it and the wires coming in in a very inconvenient way.
Try a 39-116.
RCAs ain't no cake either.
Fortunately, I did not have to do much to my GE S-22 (RCA R7A) Almost all caps and the 2 audio transformers packed into cans, and need to remove the IF transformers to get to the tabs mounting the cans. I cheated and wired the replacement caps externally to the cans and left them in place, and was able to get to the resistors on th resistor board. Fortunately the power and audio transformers were good. Ditto on the 3 1936 RCA farm sets (5BT, 6BT and spare 6BT chassis). Otherwise, you are right, early 30s RCAs can be interesting. Maybe the easiest (and least work I have done) is on my Zenith 6S52 (chassis only). Lots of room, not many parts. Yes, the 8G005 TO and 6G001 (Broadcast band only) are tightly packed. Bothof these are unrestored but function well. I believe that the 8G005 has the original filter cap.
I did R73 RCA. It has a phenolic board with all stuff mounted on it.
And the wiring is deep under everything including the longest possible antenna coil and two IF cans.
And the filter can is 1.5mm thick, probably steel as it did ot bend easily at all. I gave up trying to remove it and also cheated by mounting all the caps right on that board.
Not fun at all.
Hi Jeffcon, First off, Welcome to the Philco Phorum!, a Phamily Phriendly Phorum, Phull of Phine Phriendly Pholks and ...MrFixr55 — 07:53 AM
+1 on what Morzh and Rod said, do the caps first. I only supplied the type and replacement numbers because in your first...462ron — 07:26 AM
Philco 370LZ chair side not a 71LZ
I came across this post and I just redid my 370. My Question is: Where does the toner rod go. This one was in a bag a...Villager61 — 08:36 PM
My collection presentation
This will be a description of my twice favorite part of the collection. First, these are my favorite battery radios. S...Vlad95 — 06:25 PM
You probably don't have to worry about replacing transistors until you finish the recap. If you find that a transistor s...RodB — 10:19 AM
Start with recap. Address transistors only if needed. Testing transistors is simple and is best done with an analog ohmm...morzh — 09:01 AM
Hi Jeffcon, your HR-101 transistors cross reference over to an ECG-104 or RCA SK 3719 or an NTE104. It’s a PNP Ge (germa...462ron — 08:27 AM
Thanks RodB and morzh, Am I using incorrect terminology regarding output transistor question whether they’re NPN or PNP?...Jeffcon — 08:56 PM
Full recap is a no-brainer. By full I mean full. No caps, with the sole exclusion being ceramics/mica, if present, shou...morzh — 03:57 PM
This article has been updated. A tutorial on capacitor restoration has been added. How to repack an electrolytic cap...Vlad95 — 11:43 AM
There are currently 740 online users. [Complete List]
» 2 Member(s) | 738 Guest(s)
