Isolated variac suggestions
#31
Au Heck, it was DC. Edison said that DC was safe! Just ask anyone who touched a third rail on a NYC subway. Problem is that they never answer.
Oops, Have read too many of Morzh's stories. It's rubbing off! (And I mean that as a complement to Morzh!)
Technically, that's C-. B- is chassis ground. The resistor between chassis ground and the HV center tap makes the HV c...MrFixr55 — 11:24 PM
hello Roy, I’d follow Arran’s suggestion and use automotive gasket material, which I keep around for situations like th...radiorich — 10:22 PM
This might be one of those cases where it's a ground to an AC voltage and B- to DC.RodB — 08:22 PM
Really Rod? I know you would not steer me wrong but AI say this is a short circuit? What if I moved the 6 volt center ta...dconant — 06:40 PM
My Atwater Kent 84
