41-327 retouching black paint
This has missing paint chips on the case. Would you just use a black laquer stic on this? Otherwise the case is in good shape so I don’t to refinish it all.
Yes, and you'll be amazed at the results.
Ok. I ordered one of those this morning.
If the lacquer stick doesn’t work out it’s not that big a job to remove the chassis, mask off the black, lightly sand and respray with black lacquer.
Actually I got that in and used it this morning. Seems to work very well.
Do you just let it dry and then use wax on the cabinet or something else?
I have just been cleaning with the non abrasive Goop, using some feed n wax followed by two coats of Johnsons paste wax.
Yes I just let it dry. I would let it dry for several weeks before waxing as lacquers can take quite awhile to fully cure. I've used both the Feed n Wax product and paste waxes. Its more a matter of what you want the end sheen to be.
Hello guys,
Yes, I have used a laquer stic on furniture never on radio yet .
There are currently 1803 online users. [Complete List]
» 1 Member(s) | 1802 Guest(s)
