Emerson 25A Cap to drop voltage
I was reading this thread https://philcoradio.com/phorum/showthread.php?tid=18900 .  Radioroslyn suggests using a  6.8 mf cap to replace the  R7 305 ohms voltage droping resistor.  See attached schematic.
I have two questions, 1) My line voltage is 120V so should I use something greater? 2) I assume the cap is non-polarized, is that correct?
Thank you.
.pdf Emerson-Radio-and-Phonograph-Corp-25-A.pdf Size: 169.08 KB  Downloads: 141
Glenn
Hello Glen,
Well Here is a link to the math formula and talks about dropping capacitor.
Yes a Non-Polarized capacitor like a film capacitor can be used.
https://www.vintage-radio.com/repair-res...calcs.html
plus here is link to ARf forum about radio using
https://antiqueradios.com/forums/viewtop...r#p3934848
Excellent, thank you!
Glenn
yep, exactly 6.8uF for 120V AC.
Installed the capacitor voltage dropper with caps on hand (made a capacitor bank with 2 x 3 uF and 2 x .4 uF). Also added a 100k discharge resistor.  The radio is working well and cool as a cucumber.
Thanks again gentlemen.
Glenn
There are currently 2671 online users. [Complete List]
» 1 Member(s) | 2670 Guest(s)
