38-3 Speaker
What is an available audio output transformer that will work in place of the existing original transformer Philco 32-7754?
You need 10 kOhm load.
If you know your voice coil impedance (or at least resistance) and the power reuqired, pick from 125 Hammond series.
https://www.hammfg.com/125.htm
Let's say you have 4 ohm. (I do not know what it is).
You need 2500 times that, which would make it 50 turns ratio.
The closest one then would be output leads 2 and 4.
https://www.hammfg.com/electronics/trans.../125a-125e
125B would give you 5 Watts, 125C - 8W.
In any case, you will be able to match most speakers to most tubes in pushpul using 125.
There are currently 2601 online users. [Complete List]
» 1 Member(s) | 2600 Guest(s)
