Should one add a three-prong power cord?
So when restoring a transformer radio, is it a good idea or bad idea to add a three prong power cord and tie ground to the chassis?
I vote yes. You can lose the "Death capacitor" which can afflict appropriate pain if it fails. On the other side (the dark side,) you can lose all protection if somebody uses one of the adaptors to defeat the grounding, or if the wall outlet is wired incorrectly. I would add a fuse as well for good measure. Transformer or not, results can be shocking!
It's not a bad idea, as long as your wiring is correct and up to code. Of course the cord will not look authentic, but if you're looking to have an easy ground for your transformer-operated radio, this would do the trick (again, assuming your house wiring is up to code).
Do not add a three wire grounded AC cord to a transformerless(AC-DC) set. Even if the B- is floating (not connected directly to the chassis), don't do it.
Here is some cloth covered three conductor wire which might help with the look.
http://www.sundialwire.com/3-conductor-1.aspx
Jim
Rogers Majestic R-646
Thanks RpdB I don't think there's much difference with interstage transformers of different models other than dimersion...Vlad95 — 03:27 PM
Vlad; I looks like your set has the same problem that mine did, both a bad output transformer, and a bad audio inters...Arran — 03:21 PM
Ouch! Not often the secondary takes a hit. Wish there was a better solution. I have a good interstage transformer but it...RodB — 02:59 PM
By the way, the bypass you suggested is a rare solution in some circuits. For example, this schematics solution is used...Vlad95 — 01:43 PM
No, you are wrong, because you did not know the details. Unfortunately, only ONE winding out of six is intact in both t...Vlad95 — 01:14 PM
The output 45s are still in push-pull because the transformer secondary winding is still in the grid circuit providing o...RodB — 11:52 AM
Thanks RodB for the help. But this is not a real solution to this situation, not even a temporary one. Because the firs...Vlad95 — 11:34 AM
I was going to check the voltages as you suggested and hooked it up to my dim bulb. It appears I have a short. The bul...bobclausen — 10:34 AM
You can bypass the interstage transformer by disconnecting the primary, connect a load resistor of about 10k - 20k to th...RodB — 09:40 AM
So, here's Prince on stage halfway through Purple Rain when he stoops down to his tech and says "Rod, pull out that...RodB — 09:17 AM
There are currently 1015 online users. [Complete List]
» 2 Member(s) | 1013 Guest(s)
