Philco Socket Power Type B-60
Hi all, Recently came across this interesting piece of history. Would like to do a cosmetic restoration before attempting to get it working. Has anyone restored one of these, in particular, the right color brown for the case. Cosmetically there is little rust on the outside of the metal cabinet. Most of the paint is gone. A few spots still have the original paint. It is hard to tell if the paint was smooth or a wrinkle finish. The bottom inside of the case is quite rusty-maybe from spillage of the borax and water solution from the 4 jars? Thinking of trying muriatic acid and a wire brush to clean the inside. The brown bakelite panel insert is in very good shape. Should clean up nicely. Any thoughts? Thanks, Ken Kidd
...and, if you need the service info for Socket-Power unit, I have it through my site.
That's is good condition, compared to most I've seen.
Chuck
Thanks Chuck, Will take you up on your offer. I'm assuming the 2 tar filled cans have the caps and maybe a resistor or 2 in them. Initial cold check of transformer indicates it is good. Will post in electronic section when the time comes if I have specific questions on the electronic repair. Ken
Don't use muriatic acid, it will take the rust off but it will also make it rust again. What I would do is try electrolysis to strip the old rust and paint off, basically you need a battery charger or DC power supply, a piece of scrap metal, baking or washing soda, and a bucket of water, there are several good how to videos on your tube. Another method if you want to try preserving some of the original paint is soaking the cabinet in a 6:1 mix of molasses and water for about a week or two. It looks to me like the original paint was some sort of crackle finish, I don't even know if you can buy it anymore but there used to be a few recipes on how to make it.
Road Trip for a Philco 46-480
Beautiful work, a 79 year old radio brought back to life. The first FM radios for me, a little iffy, had some I just cou...Jimradio — 08:01 AM
I was a field engineer for a biomedical company for many years. Many was the time that I was driving home from NYC in t...MrFixr55 — 06:40 AM
Don't laugh folks, I have not been above taking a chassis into the bathtub (when Ms. Fixr was out of the house), taping ...MrFixr55 — 06:02 AM
Philco model 40-100
Marion; By "newer style" carbon resistors do you mean the molded type with coloured bands rather then the BE...Arran — 01:00 AM
hello jrblasde , your radio sounds great well done !! I bought like 20 years ago a Philco 610b that someone had painte...radiorich — 11:50 PM
Philco model 40-100
Arran, I just can't tell if the volume control has been replaced. The control has a brass shaft with one half flat for ...mhamby — 11:08 PM
Philco model 40-100
You may be able to make the part out of wood. The particular vendor has a habit of disassembling radios and selling the...MrFixr55 — 10:09 PM
Used to get to Bentonville when I worked for a Walmart vendor....nice and sleepy back then. PaulPaul Philco322 — 09:49 PM
Philco Model 249 made in England
Did Garrard produce stand-alone turntables? The reason I ask is, when I was a kid my grandfather gave me a KLH Model 20 ...jrblasde — 09:37 PM
Neat looking set, definitely Euro- style. I am guessing that this is solidstate due to the vent holes (or lack thereof,...MrFixr55 — 09:32 PM
There are currently 570 online users. [Complete List]
» 3 Member(s) | 567 Guest(s)
