Help identify a Philco Record Player
New here - be kind, please....
I've spent a good deal of the last couple of days searcing this forum and associated areas of the sight without any luck. I'm trying to find out the model umber of a Philco labeled record player that seemigly has no visible model number anywhere.
I have yet to learn how to post pics yetso I'm going to try and describe the player and hope someone can shed some light on it for me.
It's a record player only.
Low profile, Primarily grey in color and looks like plastic/bakelite.
Seems to be a 3 speed model.
Two raised Gold dials on the top front edges left and right.
Has a 45 RPM record stacker and an arm to steady stacked abums.
Rounded edges give it a 50's/60's look.
Philco label on the front center and the words "equipped with Diamond Needle" on the right front.
About the best I can do - couldn't find it in the "Gallery" here or anywhere on the internet.
any help would be appreciated....Thanks.
Hi,
I apologize for missing your post before now.
Directions for posting photos may be found here.
http://www.philcoradio.com/phorum/showthread.php?tid=29
http://www.philcoradio.com/phorum/showth...p?tid=4371
If it's a three speed phono, it was most likely made between 1950 and 1956.
"Your radio tubes get these voltages from the power transformer secondary windings. The A voltage is supplied by th...osanders0311 — 01:40 PM
Please correct me if I am wrong, while working on this radio I noticed under the chassis where the bottom of the tubes p...osanders0311 — 01:28 PM
"BTW there's a 2.2k resistor from B+ to one of the XXL tubes so you have to identify those resistors before you rep...osanders0311 — 01:04 PM
BTW there's a 2.2k resistor from B+ to one of the XXL tubes so you have to identify those resistors before you replace t...RodB — 11:08 AM
Okey dokey, let's get on the wayback machine. Back when radios were running on batteries, they were powered by three DC ...RodB — 10:34 AM
Meter is a DMM (Brymen BM-257 to be exact) Voltage being measured to the chassis Yep, just double-checked 'emsq65 — 10:22 AM
Hi Peter, As for the spkr what you are looking for is a U-2 spkr. The H style spkrs are not as robust as the U models. ...Radioroslyn — 07:40 AM
Hello Rod,  Honestly I am not sure what you mean by B+ on the schematic, I am still trying to figure it out as I hadn...osanders0311 — 05:56 PM
What kind of meter is it? Relative to what is the voltage being measured? Are the AC line filter caps C53A/B hooked up...morzh — 10:47 AM
Hi, what I'm seeing on the schematic is one wire from the output transformer goes to B+ and the other goes to the 7B5 pl...RodB — 10:42 AM
There are currently 864 online users. [Complete List]
» 2 Member(s) | 862 Guest(s)
