Adjusting the Antenna Trimmer
Hi All,
I'm closing in on my first success. I took a dead 42-PT94, recapped it, swapped out the resistors, fixed up some of the crumbling rubber insulated wiring, and it's playing quite well. Pretty exciting.
In aligning it, I get no reaction from the antenna trimmer. The IF's and the oscillator trimmers act just as they should, but no output variance from the antenna trimmer. What don't I understand? (I'll admit that's a whole lot at this stage of my education).
Alan
Well a few things come to mind. The trimmer on the tuning cap should be set for max volume at the HIGH end of the bc band. It won't have much of an effect at the low end of the dial. Does it have the original loop ant? Any damage? Shorted turns? If not the replacement may not have the proper amount of inductance.
Rogers Majestic R-646
Vlad; I was just reminded of something else, I'm not sure why but many Rogers built sets do seem to have open primari...Arran — 04:40 PM
Thanks RpdB I don't think there's much difference with interstage transformers of different models other than dimersion...Vlad95 — 03:27 PM
Vlad; I looks like your set has the same problem that mine did, both a bad output transformer, and a bad audio inters...Arran — 03:21 PM
Ouch! Not often the secondary takes a hit. Wish there was a better solution. I have a good interstage transformer but it...RodB — 02:59 PM
By the way, the bypass you suggested is a rare solution in some circuits. For example, this schematics solution is used...Vlad95 — 01:43 PM
No, you are wrong, because you did not know the details. Unfortunately, only ONE winding out of six is intact in both t...Vlad95 — 01:14 PM
The output 45s are still in push-pull because the transformer secondary winding is still in the grid circuit providing o...RodB — 11:52 AM
Thanks RodB for the help. But this is not a real solution to this situation, not even a temporary one. Because the firs...Vlad95 — 11:34 AM
I was going to check the voltages as you suggested and hooked it up to my dim bulb. It appears I have a short. The bul...bobclausen — 10:34 AM
You can bypass the interstage transformer by disconnecting the primary, connect a load resistor of about 10k - 20k to th...RodB — 09:40 AM
There are currently 1001 online users. [Complete List]
» 2 Member(s) | 999 Guest(s)
