38-7CS Antenna
Good Morning from the West Coast!
What was the original antenna on this one like? When I got it there was a large ball of uncoated, stiff wire in the space under the chassis! seemed to work ok for AM, but I'm pretty sure that the factory didn't put it there.
Jim
Hi Jim
This model was designed for the Philco High Efficiency All-Wave Aerial, an illustration of which may be seen here:
http://www.philcorepairbench.com/mystery/40-6112.htm
Alternatively, it may be used with a simple longwire antenna connected to the screw terminal in the back of the set labelled RED. At the very least, a piece of insulated wire connected to the RED terminal and run along the baseboard of the room you have the set in is better than nothing.
These models did not have built-in antennas. The first Philcos to employ built-in loop antennas were not introduced until June 1939 as part of the new 1940 model lineup.
Thanks Ron!
Every time I come here I learn something!
Jim
Well I have found 315v on the rectifier when cold. Drops off to 280 after 15 minute warmup. Checked pin 3 on both 6F6 t...murf — 04:14 PM
Thanks for the replies, I will check these ideas out and report back. murfmurf — 03:18 PM
Sorry, my mistake. murfmurf — 03:07 PM
MrFixr Honestly, I haven't done that yet and do not want to screw up the threads; maybe you could do it, or we could...morzh — 12:48 PM
Two small radios from France. Restoration and review.
Greetings; I think that it's possible that the assortment of components was the result of post war parts shortages, a...Arran — 12:18 PM
Unfortunately I can't inject any audio into the volume control. It is in the primary circuit of the antenna coil, not in...Stormlord5500 — 09:32 AM
Sounds good Gary I'll do that. I have plenty of stuff like that I can scrounge up. I am still kind of new to all this so...Stormlord5500 — 08:47 AM
Philco Battery-WWII vintage
Seems to me that this a general purpose or radio filament 6V battery of very high amp-hour capacity and very high "...MrFixr55 — 08:08 AM
Hi Morzh, From my end, no. I did not know that there are 2 threads on this topic. Maybe it should be combined.MrFixr55 — 07:13 AM
Any reason for the 2nd copy of the thread?morzh — 10:22 PM
