Understanding tuned antenna inputs
Ok I'm not up & up on everything radio. So maybe someone can better explain to me the tuned antenna inputs on the back of most 36 through 38 MY sets. Those that are used for the "tuned aerial" antennas they once sold (I have a few factory doublets stashed away). I'm assuming from reading the schematic it's simply switching to tuned coils optimized for doublet antennas (of the manufactures design or perimeters). I was playing around with one of the loop antennas and decided to connect it up to the tuned inputs. Suddenly I could actually use the antenna without tuning the variable cap itself, though when done it would still optimize reception. Of course this brought in plenty more noise and the antenna lost some of it directional characteristics.
-Brian
If you collect or are interested in antique telephones, please visit Classic Rotary Phones
http://www.classicrotaryphones.com/forum/index.php
I would suspect that it's just a way to get you to buy a Philco antenna. The older sets just have a single termination for the antenna connection for a longwire. The later set with two connections is set up for an antenna setup being fed with Hi Z ladder line in a dipole configuration. They tend to work a bit better than the longwire, quieter and a little directional.
Need Help to ID this radio 11 tube Philco
Yes the 16B as morzh pointed out. Specifically its the January 1935 model version of the 16B. There are a couple earli...klondike98 — 11:51 PM
48-482 rear panel help
Welcome to the Phorum, keithchip! How far you take a radio on cabinet restoration is a matter of personal preference. ...GarySP — 11:28 PM
I've recently finished the internal restoration of a locally purchased Philco 48-482. The cabinet is in ok shape except ...keithchip — 10:28 PM
Welcome to the Phorum, Ken! Lots of help here for all of your restoration questions. Take care and BE HEALTHY! - Gar...GarySP — 07:59 PM
Thank you. I went to your online library and found 2 schematics. I will download and compare to components!Ken D. — 06:31 PM
It is a 16B tombstone.morzh — 06:13 PM
David - sorry, I reread your post and finally saw THD - now the % figures make sense. Thanks for explaining. The PSU...EdHolland — 06:06 PM
Hi Everyone, New member but have been reading this for awhile for tips! Vaccum tubes were before my time so bear with ...Ken D. — 06:03 PM
My Philco 37-116 Restore
Thank you MrFixR55, I appreciate your comments very much. I do not detect much hum if any so I will be staying with the ...dconant — 05:15 PM
Hi DConant Yes, you can replace chokes with resistors.  You do stand the risk of increased hum.  the solution is to inc...MrFixr55 — 04:23 PM
