philco model 91 speakers
can anyone tell me if the speakers in the model 91 of 1932 are the same as the speakers in the 15 x-------------thanks
i should have said model 91 x speakers
Are the output tubes of both radios the same?
(04-21-2012, 07:01 PM)tab10672 Wrote:  Are the output tubes of both radios the same?
both of the rsdios use two 42 tubes
As long as they are the same physical size they should work because the OT pri matches the plate imp of the output tubes.
(04-21-2012, 07:14 PM)tab10672 Wrote:  As long as they are the same physical size they should work because the OT pri matches the plate imp of the output tubes.
anyone know if these radios used the same size speakers. i cannot measure the 91 x speakers before purchase -------------many thanks
I just looked...models 15X and 91X do indeed use the same speakers, K-12 (8 inch) and H-7 (10-1/2 inch).
(04-24-2012, 07:29 PM)Ron Ramirez Wrote:  I just looked...models 15X and 91X do indeed use the same speakers, K-12 (8 inch) and H-7 (10-1/2 inch).
thanks Ron--------------- thats a big help i thought they looked the same from the pictures but wasnt sure.
There are currently 1132 online users. [Complete List]
» 1 Member(s) | 1131 Guest(s)
