Silvertone Model 7048
Need somehelp with the pushbuttons. Finished with chasis and plays well but can not use the buttons. thsy will not move tuner and I am notsure if some mechanical parts are missing. I have the schematis(2) but they give no information of buttons. Any advise will be greatly appreciated.
Vaguely remember working a on Silvertone like yours with same problem. Its a mechanical system. It's pot metal I'm sure and likely an actuator has broke off.
Thank you for the reply, and that is the problem.
That silver can capacitor is an aluminum electrolytic. You should replace it with an aluminum electrolytic with the valu...RodB — 11:46 PM
