Model 49-504
When I got this little radio none of the components had been replaced. I replaced all the capacitors to include the electrolytics and bypass caps and quite a few resistors. The tubes seem to be fine but alignment was way out. I used a little Mother's Mag and Aluminum polish on the bakelite case and it looks much better than before although the photo doesn't show what it really looks like.
I also gave it an alignment and now I can scan from high to low on the dial and pull in about ten stations in the daytime. I'm rather happy with this one and it will be a keeper.
[Image: http://i180.photobucket.com/albums/x220/...F3841a.jpg]
You have a very nice set. You should be able to pull in another 10 or so stations at night, or make an externall tuned loop, say 2'X2' (plenty of stuff on web) and probably get a carrier or signal from one axis or another on almost every channel. Great cure for insomnia.
I never thought about a loop...good idea. I'd like to have one for my Atwater Kent Model 30 if I could find one that wasn't an arm and a leg like some I've ran across.
Good little set. The brown ones polish nicely. The white ones can be a pain in the thing one sits on to clean up.
I gave my sister a model 6D815 in white about 18 years ago. She recently passed away and I have it back again but it no longer plays so it's time to do some evaluating. I was fortunate in that there was little to do to it cosmetically. This is one just like it.
[Image: http://i180.photobucket.com/albums/x220/...815-W2.jpg]
[split] New member...
Well, with the replacement tuning assembly, I have finally put the unit back together and aligned the dial.  The first s...HowardWoodard — 01:01 AM
Well, finding a short is easy. Like I said, disconnect the transformer's secondary windings and see if it persists. If...morzh — 09:48 PM
Restoring Philco 96
Nice one!Stan the Man — 09:37 PM
Restoring Philco 96
I have eventually replaced the speaker and shot the video, which only shows the upper part of the dial as the hum is ver...morzh — 09:24 PM
Rogers Majestic R-646
Kinda weird to see both open Nothing weird if you remember that this radio is about 100 years old  :)Vlad95 — 07:49 PM
I believe I'm making progress, resistors have been rechecked and corrected, removed that ugly blue capacitor and more wi...osanders0311 — 07:38 PM
Thanks Morzh Yes I recapped everything and replaced almost all the resistors as well. I redid #99 with .015 safety ca...bobclausen — 07:11 PM
Well...pull out every single load of the transformer. For every winding. Unsolder if needed. Then re-do your dim bulb....morzh — 07:02 PM
Kinda weird to see both open, but once you get it up and running, really pay attention to your sound. Listen for loud cr...TV MAN — 06:59 PM
Vlad; I was just reminded of something else, I'm not sure why but many Rogers built sets do seem to have open primari...Arran — 04:40 PM
There are currently 697 online users. [Complete List]
» 1 Member(s) | 696 Guest(s)
