Just bought a FT-9 - anything to lookout for?
Your radio required an external speaker. There were two types used. One was enclosed in a round metal drum like enclosure and it was mounted on the firewall and the other was a smaller speaker mounted with a long cable. It was mounted onto a formed fabric covered metal plate. This mounted in the header above the rear view mirror and the fabric covering it matched the cars headliner. Both speaker enclosures had openings to allow the sound to be emitted. I notice in the power supply section that your receiver has a large metal can type vibrator. This should consist of a two part enclosure held together with a bit of solder at the sides near the bottom. If so, and if need be, this can be opened for inspection by heating and melting the solder while at the same time pulling the top section apart from the bottom base section. At the top right of your photo I can see an externally mounted knob. This should be for tone control. There is available a black wrinkle finish spray paint (it comes in a standard spray can) and if you remove the internal chassis from the enclosure and strip the case to the bare metal, you can refinish the case to OEM appearance.
Hal
What kind of meter is it? Relative to what is the voltage being measured? Are the AC line filter caps C53A/B hooked up...morzh — 10:47 AM
Hi, what I'm seeing on the schematic is one wire from the output transformer goes to B+ and the other goes to the 7B5 pl...RodB — 10:42 AM
schematics
The Philco Library is great for Philcos.  Great source of info. Philco Libraryslford310 — 09:59 AM
schematics
Hello MSENO, Welcome to the Philco forum and here is the schematic for that Philco! 41-290 Sincerely Richardradiorich — 09:48 AM
I double checked everything around the filter caps and it all seems to be hooked up right... Here are the voltage on ...sq65 — 09:45 AM
schematics
I'm looking for a readable schematic for a 41 290. can anyone help?mseno — 09:33 AM
Rogers Majestic R-646
Since the original schematic was in an old unreadable style, I created a new schematic diagram. Owners of this radio ca...Vlad95 — 11:09 PM
Hello Peter, What great project I am looking forward to see your progress with this console !! Sincerely Richardradiorich — 10:20 PM
Ok guys, JustRadios has me worried after reading an article about purchasing resistors and I hope that I haven't made a ...osanders0311 — 08:59 PM
Yeah, I have no idea what's going on there. I will re-check it in the morning, and also trace out the B+...sq65 — 07:55 PM
There are currently 1513 online users. [Complete List]
» 2 Member(s) | 1511 Guest(s)
