42-380 candholm
A while back a 42-380 I have been working on smoked the bias resistor part number 33-3393-1 . I found a parts chassis and the bias resistor from it is marked 33-3393-3. It is made a little different than the original physically. My crummy sears volt ohm meter is not working, so I can't get a good reading until Tuesday when I get to work. Can anyone tell me if these two parts are interchangeable electrically? Thanks.[/i]
Well it doesn't matter now anyway. Got to work where I have known good meters and both read the same...the 15 ohm resistor reads 15-18 ohms, the 31 ohm resistor reads 46-52 ohms and the 146 ohm resistor reads open. The parts chassis 6X5 tube was the only bad tube and it's toast. Makes sense the 146 ohm side is open as it's first in line after the rectifier tube I guess. I'll be making a replacement for the resistor strip.
Well, better replace the electrolytic and paper caps too before you "fire it up" again. Enough has been said about the 6X5 already. A couple of 10 cent diodes little larger value voltage divider and a fuse will do you.
I forgot to make mention of it the other day, but last week I corrected another error on my schematic (applies to both R...jrblasde — 09:27 PM
Gloritone 27 Radio
Restoring Philco 96
Restoring Philco 96
Restoring Philco 96
Restoring Philco 96
Nice find! I hope it completes your console.jrblasde — 08:45 AM
Gloritone 27 Radio
Hello john, That, is the first time I have have seen or heard of that brand and model. Welcome to the party !! Sincer...radiorich — 08:08 AM
Thank you! I’ll probably use the half-round molding and tone it to match the original. Thanks for the replies!Max T — 06:34 AM
Gloritone 27 Radio
I'm kind of late to this thread, but Buzz1151 has a 3 part restore series on the model 27: A little bit of extra t...Eliot Ness — 05:48 AM
You can get half-round moulding in various diameters at any home improvement store. That way the flat edge is uniform. ...GarySP — 12:03 AM
There are currently 1843 online users. [Complete List]
» 1 Member(s) | 1842 Guest(s)
